Neat
Galaxy S7 Edge screen flicker issue
JUMP TO SOLUTION
After having my new phone for 2 months with no exposure to water and no drops my screen started flickering and having a green tint after getting that i started researching this. Although i didnt find answers i found alot of people having the same problem. Now while im getting my replacement i want to know what possibly could happen because my phone didnt suffer drops and no other things that could cause this problem if anyone knows anything about this i would really like to know.
1 SOLUTION
Honored Contributor
Re: Galaxy S7 Edge screen flicker issue
JUMP TO SOLUTION
Hello @Neat
In this case, definitely reach out to Samsung directly via Phone (1-800-SAMSUNG/1-800-726-7864) to set up a repair. Naturally you can also reach out to your carrier to see if they have a different option you might like more or maybe someone here in the Community has some other ideas!
3 REPLIES 3
Honored Contributor
JUMP TO SOLUTION
Hello @Neat
Neat
JUMP TO SOLUTION
ii did get a repaid, but i just want to know what could happen.. to be more careful with the repaired device
elfmman
JUMP TO SOLUTION
I have the same problem with the flicker issue. I do not know if they have a recalled for this phone or not but there should be since the glass is weak and can hurt you easily.
