usere9f2suSdVE
Galaxy S7 crackling speaker audio Sound problem: metal distortion.
JUMP TO SOLUTION
SAMSUNG GALAXY S7 SM-G930FZSAXEF
Numéro série: R58J653WB2T
Date de fabrication 23 juin 2017
Version Android 8 SDK26 Oreo /Mon Aug 6 KST 2018
 Hello,
Big problem of distortion of sound in the speaker of my Samsung Galaxy S7 while listening to music on the music player?
After a few minutes of its metallic distortion the sound returns to normal. This problem appears systematically after the phone is switched on in the morning; indeed I turn off every night this one.
For info I tried everything the following possibilities to solve this problem namely:
-suppression of my memory card
-wipe cache partition
-wipe data factory reset
-last software update
-cleaning with rag from the speaker grille
- try different MP3 music albums.
Nothing always changes the same problem of metal distortion!
What procedure to take to solve this annoying problem please?
 See my video of my S7 GALAXY problem: https://youtu.be/lU5QI5kViJU
1 SOLUTION
Honored Contributor
Re: Galaxy S7 crackling speaker audio Sound problem: metal distortion.
JUMP TO SOLUTION
This forum is for support of US products and customers. As your product is a non-US model and support for these models is very limited, please seek a support team for your area. You can do so by using this link: http://www.samsung.com/visitcountry  Thanks!
1 REPLY 1
Honored Contributor
JUMP TO SOLUTION
