Galaxy S9 won't connect to Cellular and Wireless network
(Topic created on: 4/13/21 5:29 PM)
BayAreaBiker
Galaxy S Phones
Hello,
My about 2 year old Galaxy S9 all of a sudden is not connecting to cellular network. It also disconnected from WiFi and not able to find any WiFi networks. First I thought that SIM card has gone bad, so contacted the Cellular service and got a new one. While changing the SIM, I popped out the SIM tray, and experienced a familiar smell matching what we call brown smell due to overheating/burning of electronics components. Never noticed any smoke.
Installing the new SIM did not resolve the issue. The phone still can't connect to cellular nor to WiFi. It appears that the radio module has gone bad for whatever reasons. Has anyone experienced something similar? Is it repairable?
I would sincerely appreciate a response. Thanks.
SamsungRei
Galaxy S Phones
Thank you for reaching out. Service would be recommended for the phone. For service options, please reach out to us via one of the following options: 1. Facebook Messenger: http://m.me/samsungsupport 2. Twitter: https://twitter.com/messages/compose?recipient_id=18768513- or by calling 1-800-786-7864
CARLOS-A
Galaxy S Phones
the wifi card probably got messed up I have a friend that have the same issue with an iPhone you can fix it but if it's worth it I don't know maybe just gett a new
phone
SamsungRei
Galaxy S Phones
Headwig10
Galaxy S Phones
I would recommend a network reset on the phone. It only messes with the network portion of the phone Cellular, Wi-Fi and Bluetooth, and fixes alot of issues. Settings, About, Reset then network reset.
BayAreaBiker
Galaxy S Phones
Thanks for your recommendation.
That's the first thing I did in my effort to troubleshoot and after switching several SIM cards. The phone is also not able to detect any WiFi signals out there.
SamsungRei
Galaxy S Phones
An Accepted Solution has been marked, and provided for this thread. The thread will now be locked for further replies. in hopes to keep the integrity of the thread from steering in a non-technical manner. We understand the solution marked may not be a solution for everyone, If you have a separate concern or question, feel free to Private message a moderator or post a new thread with additional details. Please note duplicate posts on similar subjects starting 2/1/21, will be removed in order to keep our community organized and make it easier for our users to find needed content. Remember that if you do make a new post, please include as many details about your symptoms as possible. Also, make sure that your title is a good summary of the overall situation that's occurring. Thank you for being part of the community!
