Galaxy s7 edge sudden battery drain
JUMP TO SOLUTION
I have experienced sudden battery drain at around 80% of the battery usage specially when the phone is in idle. 3 months back also this happened and a settings reset helped out the problem. But thos time even settings reset didn't help. I have attached a scrrenshot of how my last charge was spent. Please help.
1 SOLUTION
Re: Galaxy s7 edge sudden battery drain
JUMP TO SOLUTION
Thank you.. I did a internet research on most of the possible causes.. Then cleaned the cache, uninstalled oculus and its related apps. After doing all these the next time phone took more than 4 hours to fully charge while on fast charger, and now the problem seems to be settled. Im using the phone from that single charge from morning throughout,and its running fine at 31% of battery now.
9 REPLIES 9
Honored Contributor
JUMP TO SOLUTION
Hey there @PavithraWijesin
That is one serious drop off! Considering the steps that worked last time aren't working this time, it might be time to consider sending the device in for an evaluation and repair. Definitely reach out to Samsung directly via Phone (1-800-SAMSUNG/1-800-726-7864), Twitter, or even Facebook. Naturally you can also reach out to your carrier to see if they have a different option you might like more or maybe someone here in the Community has some other ideas!
JUMP TO SOLUTION
Honored Contributor
JUMP TO SOLUTION
Awesome. Glad to hear that things are doing better now.  Smiley Happy
JUMP TO SOLUTION
Thank you
EPCins
JUMP TO SOLUTION
My phone goes from 80% + o - to 0% just from calling a number(not talking). What can it be?
Honored Contributor
JUMP TO SOLUTION
@userGcdm9IIUmO
Did you try the suggestions here in this thread to fix that?
userRFVT62Mh52
JUMP TO SOLUTION
This worked for me as well. THANKS!
Gaily
Cosmic Ray
JUMP TO SOLUTION
Hi, It isn't the phone, it's the update. Everyone is having the same problem with the phone draining after the last two updates. When is Samsung coming out with a fix? Thanks!
Gaily
Cosmic Ray
JUMP TO SOLUTION
This isn't an individual phone. It is happening all over the communities after the last two updates. Is Samsung going to come out with a patch or fix for it?
