Galay s10 plus low in-call volume
(Topic created: 08-01-2021 01:18 PM)
userGYZShXtQUM
Galaxy S Phones
I have samsung galaxy s10 plus. I am having  problem with in-call low volume. I did everything  like reset the phone, upgrade softwares but nothing  fixed the issue.
Please help
1 Reply
SamsungAdam
Galaxy S Phones
Thank you for reaching out. Do you experience these symptoms if you use your device with Bluetooth headphones?
How long have you been experiencing these symptoms?
Do you experience these symptoms if you test your device in safe mode?
Do you experience these symptoms if you test your device using speaker phone?
