I am not able to charge my galaxy s7 max due to moisture
(Topic created on: 5/3/20 3:10 AM)
userXcpfrySlnp
Galaxy S Phones
I am using samsung galaxy S 7 grand max.yesterday some water get inside my phone cover.I removed the water by opening the cover.Put the phone under sunlight.I charged my phone after some time it was working fine then.But today my phone is not charging.
SamsungAdam
Galaxy S Phones
I would recommend a service repair on your device. As it has liquid damage, you would be responsible for the cost of the repair. I would recommend reaching out to our customer service team directly at 1 (800) 726-7864 so they can get you set up for service. Please have the following information available:
Full Name:
Street address:
Email Address:
Best Contact Number:
Alternate Telephone Number: (If Available)
Model Code:
Serial/IMEI Number:
1 Reply
SamsungAdam
Galaxy S Phones
Full Name:
Street address:
Email Address:
Model Code:
Serial/IMEI Number:
