My Samsung 8 phone battery drain
(Topic created: 08-02-2021 05:34 AM)
rem1948
Galaxy S Phones
My Samsung 8 phone recently started draining battery rather quickly every day with no change in my daily routine. I've checked all the features that I know, optimized power, and still drains everyday to where I have to charge it.
LongHiker
Samsung Care Ambassador
Galaxy S Phones
@rem1948 the S8 was introduced well over 4 years ago. If you haven't replaced the battery, it sounds like it is probably time.
rem1948
Galaxy S Phones
Thanks, less expensive than a new phone
S8member
Galaxy S Phones
The S8 is well sealed for water resistance. Are there places certified by Samsung that can change the battery and keep or reapply the sealing for water resistance?
LongHiker
Galaxy S Phones
S8member
Galaxy S Phones
Thank you!!
