RGB Flash camera and notification panel icon ideas
(Topic created: 08-15-2022 12:03 AM)
userNMNQyWAA
Galaxy S Phones
I think a cool feature if they put a rgb flash for the camera that you can change multi colors when taking photos to do a color flash and also a cool way to see notifications to flash colors and pick what color for each notification. And someone could create a mini light show for when the phone rings or playing music.
I also think a nice feature interface when interacting with the notification panel the icons like wifi, flashlight ect... when holding down the icon it pulls down a easy drop down. for example when holding down the flashlight icon a small drop down would give you the option of bightness instead of opening a full page all icons could have a simple dropdown to gain more control and options without a full screen page opening. For easy access.
SamsungRyder
Galaxy S Phones
Thank you for your interest in sharing your idea with Samsung. We appreciate your feedback and will tag it on the forum so that it will appear with other feedback, ideas, and requests. This will allow your post to be more easily found in the event that Samsung product groups are seeking outside feedback/requests/ideas regarding our products.
1 Reply
SamsungRyder
Galaxy S Phones
