S10e not receiving incoming calls
(Topic created: 08-14-2022 11:49 PM)
userXPVmoV0wXE
Galaxy S Phones
My Samsung S10e will not receive incoming calls. I can call out, I can receive/send text. I've been dealing with this issue for 3 weeks now and no one can fix the issue
Charkatak
Black Hole
Galaxy S Phones
It was either update that messed something up or your carrier changed some bands/technology. So I assume you have already contacted your carrier? Additionally, try a sim from another carrier (ask friends) if your device is sim unlocked.
wenmarie74
Galaxy S Phones
Factor reset
user8FWaMyiRZ3
Galaxy S Phones
Check that Airplane Mode is disabled on your device. If it is disabled but your Android phone still can't make or receive calls, try enabling Airplane Mode and disable it after a couple of seconds. Disable Airplane Mode from Android Quick Settings drawer or navigate to Settings > Network & Internet > Airplane Mode.
Regards,
Will
