Highlighted
Re: S7 Edge Lock screen PIN not working.
JUMP TO SOLUTION
Same issue, my phone just quite accepting my pin number. Wouldn't unlock at all and trying to reset wouldn't accept my gmail accouant. Verizon sending me a new phone. They couldn't get it to restart either. Wish I had found this site sooner.....Woman Frustrated
Highlighted
JUMP TO SOLUTION
Today I tried to Factory Reset but that needed my PIN - which I DID NOT HAVE - i then had to wait 60 minutes to retry.
In the mean time I got a notice that a system update was available - I envoked this and waited for the download and installation and reboot and then ----- My PIN again worked !!!!
Highlighted
JUMP TO SOLUTION
My wife phone having the same issue. She kept trying and the phone got reset. Now all pictures, videos and other personal stuff are gone. Is there away to get these pictures back???
Highlighted
Cosmic Ray
JUMP TO SOLUTION
I always have everything backed up to Google. If she did then yes if not that or backed up to Samsung then no.
Highlighted
JUMP TO SOLUTION
My S7 just got an updated lock screen app from Samsung and after the reboot (which means I cannot use the fingerprint) it is not accepting my PIN. I tried a hard power off/power on and still it does not accept my PIN. Now it warns that if I fail two more attempts the phone will be wiped?? Almost seems like that app update was malicious.
I can't use the findmymobile site because my phone was apparently never registered.
I feel pretty well stuck between a rock and a hard place.
Highlighted
JUMP TO SOLUTION
I HAVE THE SAME PROBLEM!!! DOES ANYONE RECOMMEND ANYTHING IN SPECIFIC TO DO?????? GO TO CARRER OR SIMPLY RESTART PHONE? I ONLY HAVE 3 ATTEMPTS LEFT !
Highlighted
Neutron Star
JUMP TO SOLUTION
You have 3 options. If all of them fail you will have to factory reset the phone hence wiping all data.
Finger print reader. Pin/password, and findmymobile.
I can only suggest to restart the phone in recovery mode. Clear phone cache and restart. See if that helps.
Of course if the carrier has a way to unlock it for you I would go there first.
Superman on Galaxy S7 SM-G930T, T-Mobile, Baseband:G930TUVY3APIA
To OP: click "✓ Accept as Solution" when you find an answer that works for you.
Highlighted
JUMP TO SOLUTION
same problem!!!
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
I was forced to wipe and reset mine in the course of trying more self-troubleshooting.
One particularly notable failure was with the Google Android Device Manager - it found my phone just fine and even semi-successfully overrode the lock screen, but as soon as I touched the phone and removed the Device Manager's lock, the phone's lock screen STILL came up and requested a PIN.
Thankfully I had cloud backups with both google and verizon so recovery hasn't been an unmitigated nightmare.
Of course, even though I am now fully registered on the findmymobile site, I am now too paranoid of this issue to use any kind of lock screen security at all now, so this has been a winning occasion all around!
Considering another user posted steps to actually replicate the problem earlier in this very thread, I also find it pretty disappointing that there is no official acknowledgment of an issue or any assurance of even research towards a fix.
