KristyKatt71
Re: S7 active phone will not fast charge
JUMP TO SOLUTION
My s7 has also been doing this and there is nothing on here that has helped what so ever. I can have my phone full charged and keep it in the charger and text or look at my pic and it will die in less than a hr even with the charger plugged in
Kristy Edwards
telomere1110
JUMP TO SOLUTION
Hello @SamsungTrevor,
  I am having the exact same issue.  I have tried all of the suggestions listed in this thread.  My information is as follows:
Baseband Version - G935AUCS4BRA1
Carrier - AT&T
Model number - SAMSUNG-SM-G935A
Build Number - NRD90M.G935AUCS4BRA1
 I have done both a soft and hard reset, still no luck.  Also tried to run in safe mode without luck.
I would really appreciate some assistance here.
Best.
Supernova
JUMP TO SOLUTION
Hey, @telomere1110, I really appreciate you taking the time to get in touch with us about this.
Have you attempted to charge your phone with any other cables?
telomere1110
JUMP TO SOLUTION
Yes, I've tried different cables and charging units.  All of these used to work prior to the software update but now they won't.  They are Samsung Branded and adaptive fast chargers.
Supernova
JUMP TO SOLUTION
Alright, thanks for the feedback, @uservaPjtKSxIX and @telomere1110!
Would you all mind putting your phone into safe mode to see if this affects your device's ability to charge?
1. Power your device down
2. Then power it back on
3. Pressing and holding the Volume Down key when you see the Samsung logo
Please let us know if this helps!
klb4n6
JUMP TO SOLUTION
I have done everything mentioned here multiple times.  It is NOT my charger.  It is NOT any apps I have on my phone. Putting it in SAFE mode does nothing.  It is the phone.  Everything was fine until the last software update came out.
My next phone will probably not be a Samsung, because there are multiple people here saying the same thing and there have been no solutions or admission that it's your product that's broken, not something we're doing to our phones.
userHmE5emCBit
JUMP TO SOLUTION
I agree klb4n6,
I've been monitoring this thread for awhile now.  Sad Samsung can't just say, "We understand some of our valued customers are experiencing problems related to the charging of their Samsung devices.  Our team of engineers is looking into this.  We hope to have this problem identified soon and a solution in place.  In the mean time, some of our customers have found some success with the following methods."
This is not rocket science.  It is called honest communication.
userdFwrNRui4U
JUMP TO SOLUTION
You said it, userHmE5emCBit.
Hear, hear!!!
Supernova
JUMP TO SOLUTION
Hey, @klb4n6, thanks so much for reaching out to us about this. If you have attempted all of these steps and you are still having difficulties, we suggest that you reach out to 1-800-726-7864. They will be happy to let you know about all of your repair options!
useroQs5P4EPC0
JUMP TO SOLUTION
Have you tried cleaning the charging port with compressed computer air duster?
