userQY0dNdRXcL
Re: S7 active phone will not fast charge
JUMP TO SOLUTION
Positioning the cord does not affect it. I don't see why any background apps would make a difference? Is there a reason? Regardless, even when I closer all background apps it still only fast charges sometimes. I can't find any method to the madness.
JUMP TO SOLUTION
Can I ask if there is any change if you attempt charging while the phone is in safe mode? (Can provide steps if needed)
userh7AiLpxnJJ
JUMP TO SOLUTION
It's happen on my S7 and S6 too. Try in safe mode,reset factory, wipe cache but nothing change. Now my S7 and S6 cannot fast charge via cable and PC cannot reconize phone via USB.
You can view my phone infomation at: https://drive.google.com/open?id=1HN0dvcZuykEHCZNlAA1tnETfqzLgIKSv
userQY0dNdRXcL
JUMP TO SOLUTION
How do I do that?
Red Giant
JUMP TO SOLUTION
@userh7AiLpxnJJ
If you have performed a factory data reset and those other steps, you may want to get your phone inspected and possible repaired. To schedule a repair order, you can reach out to us at 1-800-726-7864 or via the Samsung+ app. You can also contact one of our moderators in a private message, and we can submit that request for you.
usermcSIv4PJjT
JUMP TO SOLUTION
How is sending phone to repair a solution ? Expecially when it is out of warranrty.
userh7AiLpxnJJ
JUMP TO SOLUTION
Ah, my S7 and s6 are out of warranty for sure. Current it's inconvenient for me to come to Samsung service center because I'm far from city. But I think there are some problem happen because 2 phone S6 and S7 of me lost fastcharge via cable and usb connection at the same time after software update is very strange. I remember it happen at 23-26/1/2018
userLMeooEe1v4
JUMP TO SOLUTION
There isn't a "battery" under Settings on the S7 active
Supernova
JUMP TO SOLUTION
Oh! I apologize for that confusion, @userLMeooEe1v4. You may find this Setting under Device Maintenance. Keep us posted please.
userkfjPtAgloR
JUMP TO SOLUTION
I found the fast charge on off switch under battery settings, but under the advanced tab at the very bottom of the page under all the apps
