S8 Hibernating Apps draining battery and causing phone to heat up
(Topic created on: 5/5/21 12:30 PM)
Andrea43
Galaxy S Phones
My hibernating apps are draining my battery and making my phone too hot. How do I turn off hibernating apps? And, is there a downside to doing it? Thank you in advance.
charmander
Galaxy S Phones
I would Uninstall them
Andrea43
Galaxy S Phones
I use most of them, but I will uninstall the ones that I rarely use. Thanks for the tip.
Cathyfam
Galaxy S Phones
Yes, if you don't use them much you should Uninstal. It will make a big difference.
Andrea43
Galaxy S Phones
I do use them but, I will try uninstalling the ones I can live without and see if that helps.
requa
Comet
Galaxy S Phones
If you're referring to the recent apps menu, try locking the ones you want to keep readily available and running (click the app icon at the top of each in the recent apps menu then "Lock this app"). You can then use Close All to close all of the unlocked apps, and can still close locked apps individually by swiping.
Dan
Galaxy S9 SM-G960U on Xfinity Mobile + Gear S2 Classic
