S9 - Android 10 Update - Quick battery drain
(Topic created: 02-09-2020 01:47 PM)
userNjKLMgD22k
Galaxy S Phones
Never had issues with battery but after the recent Android 10 upgrade it started to darin really quick. I have to recharge phone at 2-3 pm now :(. Did anybody else notice the same issue?
I didn't install any new apps so I'm pretty sure that upgrade caused it.
JUMP TO SOLUTION
userAfJEWnW8e7
Galaxy S Phones
My apps update automatically.  Just checked and no pending updates.  I've cleared cache so hopefully this will resolve.
Thanks
userVznxvmqjR3
Galaxy S Phones
Has a solution been found other than completely resetting the phone?? Seems to be a terrible solution.
Jamess467
Sun
Galaxy S Phones
For the first 2 days, my S9 heated up after the Android 10 update, but now things got better. You can clear the cache partition, or a complete factory reset...
user9VEM6iBBCy
Galaxy S Phones
My battery life is terrible now. It was never great but now I need to recharge it twice a day.
While I keep most apps sleeping!!
I also can't stand the advise on putting the bluetooth off or location and other stuff. That is why I want this smartphone. Otherwise I would use my Nokia 3310 again. 14 days of battery life.
If I need to recharge my battery 2-3 times a day, then this is not an upgrade but a very bad downgrade.
Really disappointed here. Is this the strategy that you need to buy a new phone???!!!
Then it won't be a samsung anymore.
And then I welcome our Chinese friends.
Btw: I cleared the cache partition. No help.  Pretty sure nothing will help and that Samsung knows this.
If there is anyone who has a decent battery life after a factory reset please tell me.
Otherwise I will install an old custom rom and or change to xiaomi or others.
userwGDBB0IF7u
Galaxy S Phones
Nothing works , I tried everything.  Samsung really needs to fix this in the next update . I can't go anywhere without a powerbank to last me the hole day. I charge my s9 and on 100% i have 10 hours on moderate to almost standby only, if i leave the wifi all night long I risk to find my phone dead in the morning if I leave it on 70 % when I go to bed, 7 hours of stanby.... the battery was never great but it was almost  double the time on android 9
Dave02895
Galaxy S Phones
My s9 plus updated to android 10. I tried wiping cache....factory reset and my battery drains super fast. Battery saver modes dont help at all. I had no issues with battery till this update on sprint network..... Samsung please fix the issue with battery drain
Samsung_xRpNBFh
Galaxy S Phones
Please fix the problem with the battery drain
Njdan30
Galaxy
Galaxy S Phones
Download android 9 and use Odin to go back to android 9. Make sure you download version with the same bootloader number (7) it's the 5th to last number. And enjoy
userIp9orrvkpi
Galaxy S Phones
Hello
userIp9orrvkpi
Galaxy S Phones
Trust me I've had the same problem befor with my old phone
