S9 - Android 10 Update - Quick battery drain
(Topic created: 02-09-2020 01:47 PM)
userNjKLMgD22k
Galaxy S Phones
Never had issues with battery but after the recent Android 10 upgrade it started to darin really quick. I have to recharge phone at 2-3 pm now :(. Did anybody else notice the same issue?
I didn't install any new apps so I'm pretty sure that upgrade caused it.
JUMP TO SOLUTION
Getafix
Galaxy S Phones
On my S9+ the battery is fine till 20% then it drains to 0% in less than a minute and phone switches off.
Couple of times have charged it to around 15% and that will last for about 2 hours.
Cleared the Cache. Also done a full reset but still happens.
Any solution?
SamsungAdam
Galaxy S Phones
@Getafix Do you experience these symptoms if you test your device in safe mode?
Getafix
Galaxy S Phones
Have not tried that. Not sure how to try as today it dropped from 24% to 0% in less than a minute.
How do I switch to Safe mode say once it reaches 30%.
Interestingly, just charged it to 28%, and using it since and battery usage is as expected. This happened before. Will charge it to full later tonight and let it run down tomorrow.
Getafix
Galaxy S Phones
Ok, Switched to Safe Mode at 25%, battery dropped to 14% quickly. Dropped to 13% after about 5 or so minutes, and then dropped to Zero quickly.
SamsungAdam
Galaxy S Phones
@Getafix I would be happy to assist you further. Can I please have your full model number and IMEI in a private message: http://bit.ly/2JH2rq2
Getafix
Galaxy S Phones
Done.
Model/Serial/IMEI sent.
Along541
Galaxy S Phones
People complain when they dont have the update then people complain when they do and try to find any little tiny thing wrong
Lorikelli
Galaxy S Phones
Really?
userAfJEWnW8e7
Galaxy S Phones
My battery life is terrible since installing the latest update.  I had a new battery installed 6 months ago with a new screen and I easily got a full day out of my S9+, with quite heavy useage.
Now even if I don't use my phone much, by 4pm it's on 30%!!   Looking at app usage doesn't appear to give anything away.  I've ran maintenance optimisation and restarted phone.  I've just tried clearing the cache so will see if it is any better tomorrow.
There is definitely a problem with the update, if I use my phone moderately I'm now charging it 2-3 times a day. And that's a brand new 6 month old battery!
userNjKLMgD22k
Galaxy S Phones
I've solved this issue for both of my S9s in the following way:
1. Update all apps
2. Clear caches
Simple cache clearing didn't help, only after updating all apps.
Battery was being drained by Google Play Services. After applying of steps above its power consumption got back to normal.
