S9 - Android 10 Update - Quick battery drain
(Topic created: 02-09-2020 01:47 PM)
userNjKLMgD22k
Galaxy S Phones
Never had issues with battery but after the recent Android 10 upgrade it started to darin really quick. I have to recharge phone at 2-3 pm now :(. Did anybody else notice the same issue?
I didn't install any new apps so I'm pretty sure that upgrade caused it.
JUMP TO SOLUTION
SamsungCole
Galaxy S Phones
I recommend reaching out to your carrier.
