SD Card storage is not working and internal storage is at max capacity.
(Topic created: 10-24-2021 04:22 AM)
all4fun
Galaxy S Phones
Help set ss Card storage so internal storage has space
Je655
Red Giant
Galaxy S Phones
I would check out this post
https://www.samsung.com/us/support/answer/ANS00062607/
With your microSD card inserted, navigate to and open the My Files app.
Find the file(s) you want to move, and then touch and hold the file(s).
Tap Move or Copy at the bottom of the screen, and then navigate back to the My Files Home page.
Tap SD card - this will only show up if you have a SD card inserted. Navigate to the folder where you'd like to place the files.
Tap Move here or Copy here and the files will be placed on the SD card.
all4fun
Galaxy S Phones
Thanks for the help. I will use it
