Samsung S8 call volume pretty low during calls
(Topic created: 06-24-2020 08:53 PM)
useryX8KnirBjx
Galaxy S Phones
i noticed about 10 days ago, that when making calls, the call volume of my phone despite being set at maximum is usually low. Evey other sound is working perfectly. I dont know what could be wrong and i need help.
SamsungAdam
Galaxy S Phones
There are a few things that can cause issues with the speaker on your phone. For example, there could be an external device where the audio is being redirected to. It's possible that a software glitch or physical damage is causing the problem. Give this link a try: https://www.samsung.com/us/support/troubleshooting/TSG01001255/
If you continue to experience these symptoms after performing the troubleshooting steps provided, I would recommend a service repair. Can you please provide me with the following information in a private message: http://bit.ly/2JH2rq2
Full Name:
Street address:
Email Address:
Best Contact Number:
Alternate Telephone Number: (If Available)
Model Code:
Serial/IMEI Number:
userj27Q7dToSx
Galaxy S Phones
Same is the case with my s8.
useryX8KnirBjx
Galaxy S Phones
When did you notice yours and have you resolved it?
SamsungAdam
Galaxy S Phones
Full Name:
Street address:
Email Address:
Model Code:
Serial/IMEI Number:
