Dragon28
Cosmic Ray
Solution to no sound notification galaxy s7
JUMP TO SOLUTION
I figure out how to fix the issue!
Go to settings, applications, application manager, than message.  Somehow notification is set on block. Just unblock it
1 SOLUTION
userOpv82DRPHZ
Re: Solution to no sound notification galaxy s7
JUMP TO SOLUTION
This fixed my friends issue as well but mine is not blocked unfortunately so still not working. Going to try AT&Ts fix now. They suggest one of those tricky 500 step stand on your head while walking backward fixes lol
87 REPLIES 87
alicats001
JUMP TO SOLUTION
Did all but never found "BLOCK/UNBLOCK" checked both message and message+ Where is block/unblock?
Dragon28
Cosmic Ray
JUMP TO SOLUTION
Dragon28
Cosmic Ray
JUMP TO SOLUTION
Dragon28
Cosmic Ray
JUMP TO SOLUTION
Might say on or off. It's in that section.
WazzaFromSydney
JUMP TO SOLUTION
Thank-you!!!!! After 4 forums this finally fixed my issue
Dragon28
Cosmic Ray
JUMP TO SOLUTION
You welcome. Took me 4 months to figure out. It was frustrating because sprint techs didn't have the solution to the problem. Which inconvenience me
userVyxD0nxMMg
JUMP TO SOLUTION
Hi I've managed to get the notifications now but still no sound on receipt??
userKWymUomP02
JUMP TO SOLUTION
Same here, I get notofications but no sound. When I go to system settings for ringtone and sounds, even my notification previews are silent!
user1P2WHkqFLH
JUMP TO SOLUTION
Once you choose the "messages" app from the application manager menu, there's an option under app settings called "notifications". Click that and make sure "show silently" isn't on
