userefQdQiCeek
Re: Solution to no sound notification galaxy s7
JUMP TO SOLUTION
worked like a charm, thanks for your help!
user3aNXHgEoY0
JUMP TO SOLUTION
Wow its been over a year with no message sound till now that i got fed up, thanks!
userk0Sfn7Ig0H
JUMP TO SOLUTION
I tried this and am still not receiving sound notifications for text messages... any other suggestions?
coolblueice
Cosmic Ray
JUMP TO SOLUTION
If you are sure you have "Notifications" turned on but are still not hearing any notification sounds, then also make sure the volume level for notifications is "turned up".... This was the problem I saw on my own S7... Turning up the volume slider for notifications fixed my issue. Perhaps it will fix yours too.
Do these steps:
1. Open up settings, do NOT select "Notifications" (the obvious choice) but rather select "Sounds and Vibration".
2. From there, select "Volume".
3. "Make sure the "Notifications" slider is all the way to the right. .... Done!
I have no idea how this slider got pushed to the left on my phone.... but there it was... Moving it to the right fixed the problem for me.
Jdimasi
JUMP TO SOLUTION
Thank you dragon28
userkZp2MeJT3e
JUMP TO SOLUTION
Thank you it worked!!!!
userCG4fg7TNN6
JUMP TO SOLUTION
Thank you so much! That was exactly what the issue was. You rock! It was driving me crazy!
userViFbyQdRte
JUMP TO SOLUTION
Cool I had the same issue. I just fixed it. It worked fine on other notifications but not the messenger so I did just as you said. Fixed!
userYN0DRQT986
JUMP TO SOLUTION
This helped me! Thank you ! This IS the solution
Dragon28
Cosmic Ray
JUMP TO SOLUTION
Happy to help
