userYN0DRQT986
Re: Solution to no sound notification galaxy s7
JUMP TO SOLUTION
This helped me! Thank you so much. This IS the solution
userliaGCAxYlp
JUMP TO SOLUTION
You're amazing Dragon28!
This fixed helped me for my Samsung Galaxy Note FE.
Keep rockin'! 😉🤘
Dragon28
Cosmic Ray
JUMP TO SOLUTION
Happy to Help lol 🙅🏾‍♂️
userYwoJABIBEY
JUMP TO SOLUTION
didn't work for me Smiley Mad
Black Hole
JUMP TO SOLUTION
@userYwoJABIBEY: Does this occur if the device is booted into Safe Mode?
usertMXtMGsdqW
JUMP TO SOLUTION
If you happen to install CM Locker, press the upper left button from that app then choose Notification Cleaner, from there, press the upper right button setting then turn off the notification from messages. That means message's notification will not be muted. Hope this will help.
JUMP TO SOLUTION
Just to confirm with you:
Have you force stopped and cleared the cache of the messages app?
Have you cleared the cache partition of the phone?
Have you gone to settings> applications>application manager> then message, and verified that it is not set to Block?
user2ubRMrmT93
JUMP TO SOLUTION
That may have fixed your issue but mine would still only vibrate. I found a possible alternative solution. Go to Settings>Apps>messages>notifications>importance and click urgent. This will make a sound and vibrate when receiving messages.
I ultimately found the reason mine wasn't making a sound was due to moving my downloaded ringtone to the sd card. So I went into notification settings and changed the default sound to one of the provided sounds from the list.
