Split screen veiw when using edge panel
(Topic created: 05-05-2021 08:27 AM)
Sal14
Galaxy S Phones
Do you know how to stop my apps from opening in split-screen view whenever I use the edge panel?
LongHiker
Epic Samsung Care Ambassador
Galaxy S Phones
@Sal14
  1. Slide open the edge panel
  2. Click the pencil icon to edit
  3. Click the 3 dot menu in upper right
  4. Under the section "Open in split screen view", change from "Tap" to "Touch and hold"
LongHiker
Galaxy S Phones
@Sal14
Sal14
Galaxy S Phones
Thank you!
usergfMazn8egr
Galaxy S Phones
How do I enable split screen
