11-16-2019 05:54 PM
When I connected one of my USB cables from my S6 to my chromebook, it wasnt charging or transfering data. For for some reason my phone turned on on its own when I unplugged the cable and it turned on on its own also when I plugged it back in.
Solved! Go to Solution.
11-16-2019 08:42 PM
It may be a weak charge. Also Chromebooks probably aren't compatible because of their heavy reliance on a webapp only interface
11-16-2019 08:42 PM
11-22-2019 05:28 PM
@the-dine I think the weak charge is true, but chromebooks are supported for USB data transfer because I have done it with another cable (that broke), anyway thanks for your help
11-22-2019 05:29 PM
@The-dino sorry I misspelled your name
11-22-2019 05:33 PM
@User108 It could be the cable you are using. Not all cables are approved for data transfer.
