Volume problems
(Topic created: 12-12-2019 09:07 AM)
userAxyXbtVfmf
Galaxy S Phones
My s10+ keeps turning the volume off on the ringtone , on its own, I can't find anything to fix this or found a reason why it is why it is doing it.
SamsungZell
Galaxy S Phones
You would need to uninstalled third-party applications until you find the once that is causing your symptoms.
SamsungQue
Galaxy S Phones
@userAxyXbtVfmf Does this issue exist when your phone is in safe mode?
userdBfPYXKQqv
Galaxy S Phones
@SamsungQue @I'm having the same issue, VERY annoying and I can't trust my alarm for work now. I checked safe mode, nope not on safe mode. Can't find anything that would cause it, restarted everything and all...
Just spent a a thousand on this phone, will this issue be fixed soon? I had to actually buy an alarm clock...
SamsungZell
Galaxy S Phones
userdBfPYXKQqv
Galaxy S Phones
It doesn't do it 24/7 more randomly so that solution would mean a massive amount of work and time or just running on bare bones... So I should have just kept my S8 until all the glitches were fixed on the 10?... I kinda figured that might be the problem but it would be unfeasible for me to still enjoy my phone if I have to delete an app, wait to see if it still does that and delete another app 😑😑😑
Well thanks for the time and effort, looks like next time around I'm going to go with someone else and save myself the hassle...😔😔😔
Ellin
Nebula
Galaxy S Phones
Sounds on my phone children l completely stopped after update, Samsung store ran a complete diagnostic and had to
