Does the S21 Ultra support SD Card
(Topic created: 02-06-2021 05:24 PM)
Shenon
Galaxy S21
Wondering if the the S21 Ultra will support sd cards?
I have heard the the s21 series doesn't support SD Cards
betancd
Comet
Galaxy S21
Nike of the S21 models support microSD. On the bright side the 256 gb upgrade is only about $50 more so not too shabby and there is also a pricier 512 GB option
S21 series supports UFS 3.1 which is far faster than Micro SD by far so even though price might be higher, performance will be better across the board.
Ekamek
Black Hole
Galaxy S21
nope
Shenon
Galaxy S21
is that for all models? like are the ones sold by the carriers differ from the unlocked ones sold by Samsung?
nopen1278
Sun
Galaxy S21
No sdcard for any s21 model.
MrsThang128
Nebula
Galaxy S21
No, you can purchase an external drive. Samsung T7 appears to be pretty simple and great if you need more storage. And that's for all models of the S21.
Ekamek
Black Hole
Galaxy S21
There is a difference between external hard drive that you carry around as a separate device and have to deal with connection issues when you need it to an SD card that's internal to the phone, adding minimal weight, doesn't change the shape of the phone (or case requirement) yet provides the storage space you need for those high size image and video files you are taking with the phone.
MrsThang128
Nebula
Galaxy S21
that was supposed to read external. The post has been edited. And I don't carry mine around. I only should have to back up every so often. But I have it in case I need it.
KrysLyn84
Cosmic Ray
Galaxy S21
When I went to swap out the s21 for the s21 ultra, the guy at the store asked me if I had an SD card in the s21... I assumed it had the slot as a result.
bill-e
Epic Samsung Care Ambassador
Galaxy S21
@KrysLyn84
Heh, he was just used to asking that question of people.  No SD card in S21 series.
** If my response helps, please click on Like (Heart). If I resolved your issue also please click on Accept as a Solution so that others can benefit.
Bill
Galaxy Fold 5 512g(VZW), Galaxy Book (original, VZW), Tab S8 Ultra, Tab S4, Galaxy Watch6Classic 47mm(VZW), Galaxy Watch5Pro(VZW), M8 Smart Monitor
betancd
Comet
Galaxy S21
