userXb93GX158P
Where can I get a replacement charging brick for Dual Wireless Charger [EP-N6100]?
JUMP TO SOLUTION
I have lost my charging brick for Dual Wireless Charger [EP-N6100] and cannot use regular charging bricks. It requires the specific one that comes with the product. It is slightly bigger than the normal adaptive fast charging block.
Your help would be greatly appreciated. Thank you.
1 SOLUTION
Re: Where can I get a replacement charging brick for Dual Wireless Charger [EP-N6100]?
JUMP TO SOLUTION
Hey there!
You would be able to purchase one directly from Samsung.com.
Here's a direct link: https://www.samsung.com/us/mobile/mobile-accessories/phones/wireless-charger-duo--black-ep-n6100tbeg...
Hope this message finds you well!
^SamsungZell
1 REPLY 1
JUMP TO SOLUTION
Hey there!
^SamsungZell
