help Galaxy s10e no notification sound for text
(Topic created on: 2/28/21 5:23 AM)
user3KBvlLp5sN
Galaxy S Phones
I am getting no notification sounds for my text messages now that they did an update on my Samsung Galaxy  S 10e .
1 Reply
nopen1278
Comet
Galaxy S Phones
As long as they don't appear in silent notification in the notification panel you should hear a sound. If you are good there next check to see if a sound is selected for notifications settings->sounds and vibrations->notification sound. If that is good make sure do not disturb its turned off settings->notifications->do not disturb. And if that is fine go to messages app settings->notifications to be sur settings are turned on there.
