userNPLQsaoGOy
- Mute
- Email to a Friend
β02-21-2021 04:33 AM in
Galaxy S Phonesnotification sound reset to high level each time it connect to a bluetooth device.
the problem started about one year ago after some updates. i have installed since the latest updates, the problem is still there.
i will not reset to factory default. there should be a solution
