Battery Dies Fast on S10
(Topic created: 04-09-2020 08:49 PM)
TelleyPooh
Galaxy S Phones
Is anyone else having issues with the battery on the s10? There is no high battery usage shown but my phone does pretty fast. I am not sure if it's from McAfee running in the background or I'm downloading too many themes ( I love my themes). Does anyone have any suggestions?
userku4rQEnrsi
Galaxy S Phones
Charging safety Recomendation?
approach and chech on it
Before wipping your phone
checking output input make
the all connected your app font be scratched?
usernEnVbnkZ3h
Galaxy S Phones
Battery draining from 100 to 60 in minutes.. Anybody else having this issue
CandyKat
Cosmic Ray
Galaxy S Phones
yes,  and just since the update
Balletdanszer
Galaxy S Phones
Yes after the security updates my Note 8 battery keeps draining.
Samsung_4j3pAYH
Galaxy S Phones
Yes, this is so very annoying & this is actually ticking me off.
I seems to be charging my phone about three times a day & at times all i want to do is scream.
user0s3YMH8TLv
Galaxy S Phones
It is hardly even been a month for me purchasing this phone and with 8 to 9 hours of total standby (when I am sleeping) and 2 to 3 hours of usage the battery comes down to 20%. Is this the normal quality products Samsung is used to supply since inception for even higher end models or is it so that it's a gimmick they play by giving update and making the phone worse?
I am also getting delayed/no notifications for app which aren't even on sleep.
Does any one have any suggestions on how to have this battery drain fixed?
Requesting samsung to take care of this in their next update.
P.S: Requesting to not provide solutions like put apps to sleep manually or turn off additional functions. If I had to turn off the features Samsung provided, then what's the point of buying this device.
SiXFeeTUnDeR
Galaxy S Phones
Do you have a list of the major, non-system apps that run at startup and what is the storage on your device? ( i.e. 128gb-256gb-512gb) and how much of it is used? (i.e. 56gb/64gb - 27gb/128gb) Also, open your device maintenance and see what the ram usage is. Examples of that would look much like the ones I used for the storage, but much smaller numbers. (1.6gb/4gb) 720mb/2gb
Dw4877
Cosmic Ray
Galaxy S Phones
I have noticed that my battery is draining faster than usual. Can you fix this?
Jayhon
Product Expert
Galaxy S Phones
Hey @Dw4877 ,
Check out this website on tips to maximize your battery life.
https://www.samsung.com/uk/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Best,
Jayhon
If you found my suggestion helpful, feel free to leave a ♥ Like.
If my suggestion solved your issue, feel free  to click on âœ“ Accept as Solution.
userZmYXcZ5mOC
Galaxy S Phones
S10+ left side heating and Battery Draining Since Software Update
Software Update Information:
Security Patch Level : 1 march 2020
Left side below the bixby button gets really hot, and battery drains very fast.
Please help
Thankyou
