Highlighted
Battery Drain
Since my S10+ updated the phone has been very hot and draining a full battery within 4 hrs from 100% charge.
I am scared the phone is going to blow up.
1 REPLY 1
Highlighted
Re: Battery Drain
Below are some steps that I performed to limit the battery drain
1. Wipe cache partition
2. Go to each app's  info -->
  i. Mobile Data --> disable - Allow background data usage
  ii. Battery --> disable -Allow background activity
3. Disabled chrome, because it hogs on resources & battery
4. Disabled - Auto Sync Data
5. Disable/Uninstall social media apps
6. Used sleeping & Deep sleeping apps.
7. Always on Dark mode.
There are few more steps. Buzz me here on facebook.com/kardesai
