userL8ASbBuIQi
Bluetooth audio connection issue
Ive had an S10 plus for a few months now and everything worked fine till today. I hopped in my truck, 2016 ram,  and my phone automatically connected like it should but now i can only make a recieve calls. I can no longer play music from my phone to my truck. Every time i hit the audio button it just flips back off. Any takers? Screenshot_20191007-171955_Settings.jpg
5 REPLIES 5
Honored Contributor
Re: Bluetooth audio connection issue
1) Tried turning off your device, then back on?
2) Tried removing and then re-pairing your phone to the car?
userL8ASbBuIQi
Yes, I've tried both of those. Takes me right back to square one.
Honored Contributor
Try resetting bluetooth app/service:
Go to settings>apps>tap 3 dots on top right>show system apps>find bluetooth>go to storage and clear data.  It may clear your bluetooth devices
userL8ASbBuIQi
Just tried it. No luck.
Honored Contributor
Maybe there is an update for Uconnect?
One of the other things you can try is to reset network settings.
Settings>general management>reset>reset network settings
