Highlighted
Not applicable
Re: Bluetooth audio quality issues after update
JUMP TO SOLUTION
Seems like it got fixed after an update for the Media from the galaxy store
Highlighted
Not applicable
JUMP TO SOLUTION
Well, it is not fixed. Audio is better, but not normal, still there is some distortion
Highlighted
Not applicable
JUMP TO SOLUTION
UPDATE: after the latest update for "device media" from the galaxy store, you have to turn off the adapt sound. This will fix the issue, but you wil not be abe to use your adapt sound profile.
Conclusion: adapt sound is broke after february security update
Highlighted
JUMP TO SOLUTION
Thanks this solved my BT distortion problems after latest security update
Highlighted
Not applicable
JUMP TO SOLUTION
you welcome, bud
Highlighted
JUMP TO SOLUTION
Thank you so much,I could tell it was some sort of processing issue but didn't think about adaptsound. Don't hate my phone anymore
Highlighted
JUMP TO SOLUTION
Has anyone had the issue where their bluetooth setting keeps toggling off the audio...so it allows the paired device access to calls but will not for some reason allow it audio access. This is an issue i have been having in my car...it's a new issue too.
Highlighted
JUMP TO SOLUTION
Hi guys,
Same issue here with the Note 9. Audio quality on my Buds+ are just awful!! The sound volume seems to constantly go up and down, right and left, on Spotify and Youtube. Tried the original AKG earphones and everything seems fine. Don’t know if this has only to do with bluetooh or the Adapt Sound feature.
Any news on a fix?
Thx!
