SLEhrgott
Edge panels not working right no matter what I try
I have read the threads containing what is supposed to fix the issue and it has not worked.. have tried wiping cache and data, reinstalling, turning off and on, restarting.. Everything.. is there a fix it not for not?
1 REPLY 1
Re: Edge panels not working right no matter what I try
If none of the troubleshooting steps have helped the symptom I would recommend having a certified technician evaluate the device.
