users0rO59L4fG
Galaxy S10+ won't charge when battery is dead
Hey guys... This is my first post so please forgive me for any mistakes I make lol I'm having a small and weird issue with my phone. I bought the Galaxy S10+ unlocked via Samsung and I have had it since it was released and I just noticed this issue 2 days ago. My phone battery died for the first time since I had it and when I plugged it in to charge, I noticed that it wasn't charging and there was no animation either. I tried to start it up while plugged and nothing. So then I tried to wireless charge it and it started to charge and had the charging animation and all. After that I was able to turn my phone on with like 1-2% battery life and plug it into the wall charger and the phone charged normally... Weird right???!!??? Anyone else had this small issue or am I doing something wrong here??? Lol thanks for the help guys....
17 REPLIES 17
userjE2tzbLFaX
Re: Galaxy S10+ won't charge when battery is dead
This just happened to me. I also have the unlocked version of the s10. I’m also having connectivity issue’s.
users0rO59L4fG
Heyy... Good to know that I'm not alone... It's weird that it doesn't charge whatsoever with a dead battery... Don't know if it's a software or hardware issue... I also did noticed I don't have the same amount of LTE service bars with this S10+ compared to my old S7 edge
userFZe6KdXNz8
Samsung is this an issue with all S10 phones?
Samsung_0Mbu69d
Same thing happened to my s6edge and it was the charging port going bad (hardware),while the wireless charging was still good. Weird for it to happen in a new model so quick though
Samsung Care Ambassador
Sounds like it could be a charging port issue. You could take it to your nearest uBreakiFix for a quick diagnostic
userFH8PeNdmAR
Hello everyone I just got a brand new new Samsung s10 e from EE and I have the exact same issue.  Again it won't charge from a wall plug when completely dead but will charge from a charging plate. Once it had some charge it will then charge normally from a wall plug.   Xx
Avoid draining those batteries down below 15-20%. I know it's not always possible to charge up when the battery is running on fumes, but you'll see the effects of degradation if you're running that charge down to 1-2%.
If you've found my post to be helpful, please like the post. If my response helped resolve your issue, please press the "✓ Accept as Solution" button. Thanks!
SM10
Same for me, my battery drained and it wont charge, not even wirelessly. Has samsung given any formal answer ?
userOgeJJdkUnS
I have the same problem.
When the battery if fully drained, it does not respond anymore to charging devices.
Sometimes I do see the charging icon, but not the animation. It seems like it is not charging at all and the phone can't be turned on.
For some reason I can only start the charging by connecting it to my laptop.
And yes, I'm only using original Samsung accessoiries.
