nanivijay
Ring doorbell speaker volume very low if answered ring from Galaxy s10+
Ring doorbell speaker volume very low if answered ring from Galaxy s10+. Anyone facing this issue?
42 REPLIES 42
Re: Ring doorbell speaker volume very low if answered ring from Galaxy s10+
Does this happen if your device is in safe mode?
userm7KXzjGoHp
I have the same issue, what do you mean by does it happen while in safe mode? @SamsungAdam  @nanivijay
@userm7KXzjGoHp You can use the following link to test your phone in Safe Mode.
http://www.samsung.com/us/support/troubleshooting/TSG01001188/
userR15W6cnQUy
Cosmic Ray
So I can verify that I don't get the static noise when going into live view. It also fixes the low audio issue. It's now loud and clear.  However we are now missing the event time-line, a feature I liked. So we can't have both?
nanivijay
No. If I reset my ring app it works for few minutes and then the same problem is reoccurring
userm7KXzjGoHp
I just installed ring pro doorbell and have same issue. I am on Samsung s10+. My spouse's s7edge and son's iPhone sx work perfectly well with the ring always home app.  I called support for ring and everything looks good on their end.
nanivijay
I have s9+ and I am not facing the issue with ring devices. I am not sure whether it's software or hardware or app issue.
@nanivijay If the issue does not occur in Safe Mode, there is a 3rd party app interfering with the normal function. You would need to determine which app is causing the issue and uninstall it.
userzZ94pAo6JQ
Did you find a fix to this? I'm having the same exact issue on my ring doorbell and other ring cameras. No issues with any other phones I try to use, just the s10 plus. I have heard that noise reduction may mess with a phones microphone but I don't see any setting to turn off noise reduction.
