- Mute
02-27-2019 07:54 AM (Last edited 03-28-2019 01:59 PM by SamsungAdam ) in
Galaxy S PhonesIs the LED Notification light missing from the S10 phone, if it is is there a workaround to get it, or will there be an update and they will add it?
Also if it is, I am very disappointed and considering not getting the new phone.
Solved! Go to Solution.
- Mute
03-12-2019 12:35 AM in
Galaxy S PhonesI truly want to take my S10 plus back. It's really annoying that I have to go pick up my phone to see if there is a notification.
- Mute
03-12-2019 01:17 AM in
Galaxy S Phones- Mark as New
- Mute
03-12-2019 10:22 AM in
- Mute
03-28-2019 09:44 AM in
Galaxy S PhonesNO!!! This is ABSOLUTELY NOT A FIX!!! I REALLY WISH PEOPLE WOULD STOP POSTING ABOUT THIS "app they found" called Always On Edge.
It is an AOD tool, not a notification light. AOE is a wildly-complex product with a thousand features, and highly-intrusive ads that make you watch 30-60 second videos EVERY SINGLE TIME you click the "save settings" button (so it takes 3 hours to make 10 minutes worth of setup changes).
But it does not include the ONE SINGLE feature I need: a battery charge indicator light, red for "charging" and green for "charged". It is an insanely complex, ad-driven product that disables any other AOD features and replaces it.
Samsung needs to get off their duffs and get this required feature working. Using the built-in AOD is not sufficient to see if my phone is charged, or if I have a notification from across a lit room. I don't want to have to walk over to my phone and tap the screen just to see if my battery's done charging.
- Mute
04-01-2019 05:15 AM in
Galaxy S PhonesI'm right there with you, but there's literally no evidence whatsoever that they're going to make this a feature. I agree that AOD is pretty awful. Unfortunately outside of using a third party app it's what we're stuck with.
- Mute
04-05-2019 06:42 AM in
Galaxy S PhonesHoly smokes dude! Enough with the repeat posts linking to your beloved app. First it doesn't even work like you are saying it will and second not everybody wants to rely on a 3rd party app.
- Mute
03-12-2019 10:17 AM in
- Mute
04-01-2019 05:14 AM in
Galaxy S PhonesThis is not a fix. Stop promoting it as though it is.
- Mute
04-08-2019 10:15 AM in
Galaxy S PhonesThis is not a fix. This is a third party app that does not work as this functionality should expectedly work.
- Mute
03-23-2019 07:52 PM in
Galaxy S PhonesHahah, looks like some1 beat Samsung to this turtle speed. There's an app in the play store, " always on edge, edge lighting".
