sivartk
Re: UnHappy With this DEsign
JUMP TO SOLUTION
My OG Pixel had a light but it was so small you could barely see it from an arms length so I guess I'm not missing something I never had.
I remember it when I had an S6, but don't remember finding it that helpful.
useriWM4gTDRiK
It would be nice if the good Lock would without having to...
JUMP TO SOLUTION
It would be nice if the good Lock would without having to use the AOD feature or at least work when the screen is off. Makes no sense to have the notification light up only with the screen is on...
Samsung_m37u70L
I agree with everyone else I miss it
JUMP TO SOLUTION
user9RZXsGFHKm
Its definitely a great disappointment for me.
JUMP TO SOLUTION
userbD940JlRqj
Re: S10/S10+ Led Notification Light Missing
JUMP TO SOLUTION
Definitely a thing I miss most coming to an S10... If this continues, my next phone definitely won't be a Samsung
Ejm5560
Halo
Use the good lock app that is official from Samsung and i...
JUMP TO SOLUTION
Use the good lock app that is official from Samsung and it helps with edge lighting as an alternative for LED notifications. You can do many things including making the camera cutout light up for your notifications. It may be implemented later on with an app software or something.
usercWgDn8xfk8
JUMP TO SOLUTION
Samsung needs to put out update asap. Very annoying, stick with older model till they resolve this. Handle On Call for hospitals and it was handy. Now I constantly need to check for notices or turn on volume.
bmdpcs13
I've had goo
JUMP TO SOLUTION
I've had goo
bmdpcs13
I've had good luck with the app Always on Edge
JUMP TO SOLUTION
Samsung_TW251mv
I miss the led notification its frustrating not seeing th...
JUMP TO SOLUTION
I miss the led notification its frustrating not seeing the led when phone is on silent.
