userJbXrRoIUI7
S10e does not vibrate for incoming calls when ringtone is set to vibrate
JUMP TO SOLUTION
I always have my phone set to vibrate. Text messages, emails, social media all vibrate when ringtone is set to vibrate.. incoming calls come in as silent, causing me to miss them ALL unless I happen to see that someone is calling. I cannot have my phone set to an actual ring tone while at work, so it needs to vibrate to let me know someone is calling. I have talked to multiple tech people from Samsung and they cannot figure it out. I'm assuming it is some kind of bug. If I set my ringtone to use an actual ringtone, there is then an option where I can choose to have the phone vibrate while ringing.. but it is only if the sound is on. The option is grayed out if you are in vibrate mode. Has anyone else experienced this? It is driving me crazy and may cause me to get a different phone. Edited to add: Samsung techs have remoted in to my phone to play with the settings and have not been successful with fixing the issue. If no one else has experienced this, is it possible I got a lemon and should try returning the phone?
1 SOLUTION
userJbXrRoIUI7
Re: S10e does not vibrate for incoming calls when ringtone is set to vibrate
JUMP TO SOLUTION
Thank you all for your help. I just did an update, and within about 2 minutes of the update finishing, I got a call and my phone started vibrating! It was still not vibrating for incoming calls as of this morning and I didn't change any settings so the update must have done something to fix it!
15 REPLIES 15
Samsung Care Ambassador
Re: Phone does not vibrate for incoming calls when ringtone is set to vibrate
JUMP TO SOLUTION
Settings>sounds and vibrations>toggle sound mode to vibrate
userJbXrRoIUI7
JUMP TO SOLUTION
Have done that! Samsung techs have even remoted in to my phone and played with all the settings. Just wondering if anyone else has this issue or if I got a lemon!
JUMP TO SOLUTION
Do you have any devices connected to your Bluetooth by chance
userJbXrRoIUI7
JUMP TO SOLUTION
My fitbit!
userJbXrRoIUI7
JUMP TO SOLUTION
Just disconnected from bluetooth and tried to call my phone.. still did not vibrate.. There has to be something I'm missing!
JUMP TO SOLUTION
Try putting the device in safe mode and see if your vibration works
userJbXrRoIUI7
JUMP TO SOLUTION
Just tried and still did not work
JUMP TO SOLUTION
@Rydah
JUMP TO SOLUTION
Hey @userJbXrRoIUI7, have you tried clearing the settings for the phone app?
Also, I didn't see it mentioned but I assume Do Not Disturb mode isn't on and if it is, calling isn't restricted?
Best regards,
Rydah
If you've found my post to be helpful, please like the post. If my response resolved your issue, please press the "✓ Accept as Solution" button.
