Highlighted
Does the Samsung S20 Ultra 5g have Edge handle and Edge panel
Does the Samsung S20 Ultra 5g have Edge handle and Edge panel?
The user guide discusses Edge panels & Edge handle functions but I do not have this on my phone.  I assume the earlier versions do but the latest...   I also do not have Smart Select function.
2 REPLIES 2
Highlighted
Re: Does the Samsung S20 Ultra 5g have Edge handle and Edge panel
Have you followed these steps to set up the edge panel? https://www.t-mobile.com/support/tutorials?page=topic/settings-amp-tech-specs/how-to-set-up-apps-edg...
Highlighted
I do not get the Edge panels selection on the Edge screen.
And, a phone search of the term ‘Edge Panel’ comes up empty.  Not on phone.   I am stumped.  Do I have a bad phone.  Is it not offered on this version of phone.  I use At&t.   Any help will be greatly appreciated. SmallerResized_S20 Ultra 5g lack of Edge Panel. Why.jpg
