Problem with Galaxy s20 ultra wireless charging.
(Topic created: 03-09-2020 07:02 PM)
user0ebOig2Oyq
Galaxy S20
So I have a galaxy S20 ultra and having a problem with it charging wireless in my wireless car charger. At first I thought the charger might be defective or uncompatible with the phone. The charger works fine with my wife's S20+ but not the ultra. Also it works fine when I use both my wireless charger at home. The problem is it would charge then pause then charge then pause every 2 second. I tried turning fast wireless charging off and it still didn't change anything. Any help would be greatly appreciated.
JUMP TO SOLUTION
Neurosis
Galaxy S20
bought a wireless car charger for my new S20 Ultra 5g and this exact thing is happening.
every 2-5 seconds: fast charging => charging => paused
Very frustrating. How has this not been fixed? It makes a key feature to the phone unusable.
Savvysawce
Galaxy S20
Verifying the same issue with a new S20 FE 5g.
Every time I place it on the wireless charger it reads "Fast Charging" for about 2 seconds and goes back to normal speed. I'm using the same brick and USB cable to power the wireless charger that gives my phone a fast charge when plugged in.
SEND HALP
lxRavenxl
Galaxy S20
Its blocked intentionally. Only Samsung official pad or certified by Samsung pad will be able to do Wireless Fast charging.
Fast wireless charging will only be enabled on devices that have been certified by Samsung and the Wireless Power Consortium. If you are using a non-Samsung wireless fast charger, check with the manufacturer or WPC homepage for the charger's certifications.
Refer the official link below.
https://www.samsung.com/us/support/troubleshooting/TSG01001490/#phone-is-not-charging-with-wireless-...
SEND HALP
userWatcMLFfHz
Galaxy S20
If this is true, why does my Samsung Galaxy S10 fast charge wirelessly for the whole duration?
Dnice007
Galaxy S20
I checked the WPC site & my chargers are all listed (iOttie stands) yet fast wireless charging doesn't work. Worthless response from Samsung.
userjMidPzwKs3
Galaxy S20
Galaxy note 5g
Also no longer fast charging even though quad lock wireless charger is listed on the database
user1b01SWW4mX
Galaxy S20
After update my s20+ 5G to android 11 still the same problem with wireless charger xD i don't belive 😞 Samsung, what are you doing :<
HwoALanG
Galaxy S20
same issue.
after the update, QI charge stopped working. doesn't even work with normal Wireless Charging. my Galaxy Fold works just fine, so as Galaxy Watch 3... this is very annoying.
jnades
Galaxy S20
mine worked fine the other day. now, not so much. the wireless charger blinks blue then green then blue again so I know there's power going to it. if there's a setting I need to turn on that got turned off some how, please let me know. p.s. my wireless charger is a Samsung fast charge pod thingamajig.
userBlyr8V9alV
Galaxy S20
FIX THIS SAMSUNG!!!!!!
