- Mute
‎03-09-2020 07:02 PM in
Galaxy S20So I have a galaxy S20 ultra and having a problem with it charging wireless in my wireless car charger. At first I thought the charger might be defective or uncompatible with the phone. The charger works fine with my wife's S20+ but not the ultra. Also it works fine when I use both my wireless charger at home. The problem is it would charge then pause then charge then pause every 2 second. I tried turning fast wireless charging off and it still didn't change anything. Any help would be greatly appreciated.
Solved! Go to Solution.
- « Previous
- Next »
- Mute
‎03-22-2021 05:26 AM in
Galaxy S20My T-Mobile S20 Ultra 5g just updated to the latest software, and now Fast Wireless Charging won't work with any of the fast chargers I have. This worked fine before the update, so I know it's a software issue. This needs to be fixed ASAP!
- Mute
‎03-25-2021 04:44 PM in
Galaxy S20Same issue
- Mute
‎04-18-2021 01:41 AM in
Galaxy S20Same issue.
Samsung, why did you decide that limiting third-party charging is a good idea?
Your proprietary wireless chargers don't cover all use cases - car, bike, motorcycle mount chargers.
Seriously, this is unbearable. I buy a phone from a top line and it cannot be charged with wireless charging on my bike, while a Chinese phone, which costs 3 times cheaper, charges without problems.
Samsung, wake up and fix it!
- Mute
‎04-27-2021 02:29 PM in
Galaxy S20I have same issue in Samsung s21 ultra
- Mute
‎04-28-2021 06:37 PM (Last edited ‎04-28-2021 07:04 PM ) in
Galaxy S20Same problem with s21+ what is this Samsung? flagship phones and can't use a wireless car charger due to your software blocking it? Even know your site says it's a supported brand and it works with S6/s7/s8/s10
We know it works because it starts charging but then your software stops it.
Come on now show some customer support, the 'troubleshooting' is done, this is a software issue made on purpose and the devs need to fix it.
- Mute
‎05-11-2021 10:22 PM in
Galaxy S20The software is a bit dodgy, try locking the phone and then placing it on the charger while its locked.
Let me know if this works.
- Mute
‎05-12-2021 10:07 AM in
Galaxy S20I recommend that you follow these steps here
If these steps do not work then your unit will require service. Please feel free to reach out to us directly via one of the following options and include a link to this thread.
1. Facebook Messenger: http://m.me/samsungsupport
2. Twitter: https://twitter.com/messages/compose?recipient_id=18768513
3. Or you can use the following link below to request service. https://www.samsung.com/us/support/service/
- Mute
‎05-12-2021 06:13 AM in
Galaxy S20I have a similar problem with the original Wireless Charger Pad EP-P1100, adapter EP-TA800 and S21. The fast charging used to work on the previous S10e but it is not working on S21 😞 (Wireless fast charging is enabled in the settings)
- « Previous
- Next »
