- Mute
‎03-09-2020 07:02 PM in
Galaxy S20So I have a galaxy S20 ultra and having a problem with it charging wireless in my wireless car charger. At first I thought the charger might be defective or uncompatible with the phone. The charger works fine with my wife's S20+ but not the ultra. Also it works fine when I use both my wireless charger at home. The problem is it would charge then pause then charge then pause every 2 second. I tried turning fast wireless charging off and it still didn't change anything. Any help would be greatly appreciated.
Solved! Go to Solution.
- Mute
‎10-10-2020 01:41 AM in
Galaxy S20I'm having the same problem. Please fix.
- Mute
‎10-11-2020 02:05 AM in
Galaxy S20Same problem here, i did the update yesterday now phone wont wirelesly charge, my wife has not dont the update and hers still works fine, Hope this is sorted asap
- Mute
‎10-11-2020 06:32 PM in
Galaxy S20I've got the same problem. Is this a defect or a software/firmware issue?
- Mute
‎10-11-2020 08:34 PM (Last edited ‎10-11-2020 08:36 PM ) in
Galaxy S20Also experiencing the same issue on the S20. I replaced the cable on the iOttie car charger, used a QC 3.0 12v plug, it will start Fast wireless charging and stop 5 seconds later. Tried switching to regular wireless charging, still dropping. Wireless charging working on home chargers. So annoying.
- Mute
‎10-11-2020 11:21 PM in
Galaxy S20Samsung has broken wirelss charging in the latest update, same thing has occured on my note 20 plus.
Wirelss charging was working perfectly before the update, now my phone switches from fast charging to normal charging every 2-5 seconds going back and forth.
Tested the charger on my S10 plus and s9. Both are working.
Samsung support wanted me to send my phone in, I reiterated that it wasn't a hardware issue but a software one. I pointed them to multiple threads where many have the exact same issue....refused to acknowledge.
- Mute
‎10-13-2020 03:00 PM in
Galaxy S20I have 3 S20 5G phones that were wirelessly charging well up until the October software update was installed. As soon as the update was installed wireless charging constantly cycles and pauses in approximately every 10 seconds. If I reboot the phone and place on the charger while the phone reboots, the phone cycles but does not pause charging. Given this issue and the fact that all 3 phones also intermittently miss calls and texts randomly even while in a very strong signal area im not overly impressed with these phones that each cost over $1000. Up until now I was very impressed with the several Samsung products I have had but this is changing my mind. Samsung needs to step up their game, this is not the quality I have come to expect.
- Mute
‎11-30-2020 10:37 AM in
Galaxy S20I have the same issue with my Note 20 Ultra. My iOttie wireless charger worked flawlessly on my Note 8 and Galaxy S10. iOttie customer support confirmed that the most recent software upgrade broke the charging with "non-certified" chargers. Since when did Samsung have to certify every wireless charger and breaking those that are not.
Please change your software!! I have $150 in two chargers that I cannot use.
- Mute
‎10-15-2020 08:16 AM in
Galaxy S20- Mark as New
- Mute
‎10-10-2020 07:52 PM in
Galaxy S20After the last s20 update 10.10.2020 my wirless charging system keeps pausing every 20seconds then going to fast charge then normal charge then pauses.... Anyone got the same problem or have a fix??
- Mute
‎10-10-2020 09:11 PM in
Galaxy S20I didn't get the October update yet.... w/ Verizon.
Out of curiosity, which wireless charger are you using? I have one that I got to use with my Galaxy s8+; Is the one you're using more powerful than that one? I assume it must be.
FYI, I stopped using the wireless charger with my s8+ as I heard it wasn't that good for the battery; have things improved with the current "wireless charger" and the S20???
Once I get the Oct. update w/ my phone I can check to see how my wireless charger works with the S20...
