Highlighted
help need help my phone doesn't have live focus
My 0hon doesn't have live focus I reset my phone and now there s no live focus
2 REPLIES 2
Highlighted
Re: help need help my phone doesn't have live focus
how do I get my contact back they was deleted
Highlighted
Sun
when you're in the Camera, slide over to more on the bottom and Live focus should be there. You can tap and hold and drag it down so you can see it everytime you go to the camera. I hope this helps.
If you've found my post to be helpful, please like the post. If my response resolved your issue, please press the "✓ Accept as Solution" button.
