Squatingcactus
- Mute
05-06-2021 11:04 PM in
Galaxy S21
Did they just remove this feature. I noticed it like yesterday after trying to take a photo of something. It's literally the only way I ever open my camera.
Solved! Go to Solution.
Robdizzle562
Halo
- Mute
05-06-2021 11:43 PM in
Galaxy S21
It's still there. Hold the power button,power settings should come up. Under it is the side key menu, click it and there you can change camera setting. Thumbs up if it worked.
Robdizzle562
Halo
- Mute
Galaxy S21
Squatingcactus
- Mute
05-07-2021 12:46 AM in
Galaxy S21
Yeah weird mine turned itself off and was in a different area than I thought
Thank you
Thank you
