Edge to edge
(Topic created: 02-13-2022 10:35 AM)
DugLop
Halo
Galaxy S21
There used to be a setting in video player to increase your edge to edge size for videos I can no longer find that setting what happened to it
PaperStation
Supernova
Galaxy S21
he's asking about video player...
you should be able to tap on the icon on the bottom right to switch between modes to select "fit to screen"
user751201tmO21
Honored Contributor
Galaxy S21
To be clear, are you asking about the Camera app or Gallery app ?
PaperStation
Supernova
Galaxy S21
