- Mute
ā05-10-2025
12:38 PM
(Last edited
ā05-12-2025
02:49 PM
by
SamsungRei
) in
My phone will not lock! My home screen keeps changing to something I don't want! My battery dies in at a remarkable rate like never before! I leave for a cruise in 2 weeks... please fix it!
- Mute
ā05-10-2025 06:21 PM (Last edited ā05-10-2025 06:26 PM ) in
Galaxy S21This is a peer-to-peer user help forum. No one from Samsung is reading your posts. If you have a specific issue that others may help you with, post it or put in an error report through the support tab in the Members App.
https://us.community.samsung.com/t5/Tips-Tricks/How-to-Send-Feedback/ba-p/3001692
After any update, battery life deteriorates for a bit, but usually quickly rebounds. This was a major update of both the OS and the UI and, thus, takes more energy. It will take 7-14 days (could be less) for the adaptive battery to relearn your usage pattern. In the meantime, the update is still putting things in place behind the scenes and all your apps are updating, as well. When that settles down, your battery life will return to normal or even get better. Look around the forums, many people who were griping about the battery life initially are now saying the battery life actually improved later on. Be patient. By the time you leave for your cruise, it should be sorted. Cruise ships have power outlets and USB ports in the cabins, so it shouldn't be an issue to keep your phone charged. You should carry a power bank with you anyway for when you are out and about on excursions or exploring.
Can you elaborate more about your phone not locking and your home screen changing?
- Mute
ā05-11-2025 05:14 AM in
Galaxy S21About my lock screen, I always put my cabin number and name on my lock screen in case I lose it on the ship. I had it set up but with the update I will pick up my phone and my lock screen has changed ge to the default screen. I then have to go into wallpaper setting and select the one I want. I have had to do this about 10 times yesterday. Ok so far today. It changes my home screen to match the default lock screen!
- Mute
ā05-11-2025 05:38 AM (Last edited ā05-11-2025 05:42 AM ) in
Galaxy S21Are you by any chance using Zedge for wallpapers? Someone else had a similar issue with the wallpaper changing and it seems there was a setting in Zedge to auto backup the wallpapers and that was causing the wallpapers to change. If you use Zedge, check the settings.
- Mute
ā05-11-2025 03:17 PM in
Galaxy S21- Mark as New
- Mute
ā05-11-2025 03:46 PM in
- Mute
ā05-11-2025 05:17 PM in
- Mute
ā05-11-2025 05:31 PM (Last edited ā05-11-2025 05:31 PM ) in
Galaxy S21Well, I have seen a lot of complaints about this issue and no solution. Perhaps you should put in an error report.
- Mute
ā05-11-2025 05:34 PM in
- Mute
ā05-11-2025 07:24 PM in
Galaxy S21Cheers
3Fees
