Poor signal, running slower, power button on side changed
(Topic created: 06-14-2025 09:40 AM)
useriwdDGBVBcE
Galaxy S21
Who ever okd this recent update must worked for apple.
It's slower. Signal not soo good.
Taking away the power button on the side. It will take some time to get used to it.
It seems more apple.
I may as well go to Apple. I can geta free one.
useriwdDGBVBcE
Galaxy S21
Thank you for commenting quickly. The instructions were a huge help.
Thank you again
Robin621k
Honored Contributor
Galaxy S21
You're welcome!
VoidedJaguar164
Galaxy S21
I've had nothing but trouble since update. I can't use my phone away from home. I have to be connected to Wifi for anything to work.
realaud
Honored Contributor
Galaxy S21
Your best bet would be to make sure you have a current backup and reset your phone.
realaud
Honored Contributor
Galaxy S21
My update went perfectly
