S21 Ultra Wireless Fast Charging Doesn't Work With USB-C to 3.5mm Headphone Jack Adapter
(Topic created: 03-19-2021 01:17 AM)
userqWNLESRrD6
Galaxy S21
I think I discovered a software bug with the wireless charging feature on the S21 Ultra. I recently bought a Qi wireless charger for my car that supports wireless fast charging (10W). For some reason, whenever I plug in a USB-C to 3.5mm headphone jack adapter (Samsung EE-UC10JUWEGUS) it changes the charging speed to a slower one. As soon as I unplug the jack adapter it goes back to fast charging. I tested my phone out with other Qi chargers that support 10W fast charging with and without the jack adapter and I get the same results. I then tried plugging in a normal USB-C cable (not connected to any power source) and the wireless fast charging worked fine. Therefore, the problem must be with USB-C to 3.5mm jack adapter. I tried using an older Note 8 with the jack adapter and the wireless fast charging worked fine. This is rather annoying because my car does not have Bluetooth and I need that adapter to listen to my music, get directions from google maps, and make calls.
CalderCay
Supernova
Galaxy S21
You can submit a "report" via the Members app.
Navigate to home page
At bottom, tap Get Help
At that page, you will see Error Reports
CalderCay
Supernova
Galaxy S21
Interesting ... we have the new Samsung wireless tri charger ... and I have the Samsung USB-C to headphone jack adapter ... I will test this in a bit
BTW, just to let you know, there are USB-C charging cables that have a 3.5 headphone jack splitter, though I'm unsure of the quality
userqWNLESRrD6
Galaxy S21
Thanks for testing this out. I knew about USB C splitters being a thing, but I had extra cash to splurge and thought a wireless charging car mount would an elegant solution to my problem.
CalderCay
Supernova
Galaxy S21
Well, you're correct ... I see the same behavior ...
It takes longer to wirelessly charge the phone when the USB-C adapter is plugged in.
Check out my screenshots - one with, and one without, adapter, and showing estimated charging time.
userqWNLESRrD6
Galaxy S21
Man this is such a niche problem, I wonder if Samsung will fix this. Any idea who I can report this to?
CalderCay
Supernova
Galaxy S21
