Warning: Camera Failed Notification
(Topic created: 12-25-2021 02:08 PM)
BenStewart95
Samsung Apps and Services
Hey everyone!
I've seem similar problems to mine, but hoping there will be a solution soon.
My phone is the Galaxy S21+ 5G.
Upon opening Camera app I receive the message "Warning: Camera Failed". Other apps utilizing the camera also no longer are able to. Trying another Camera app does not work as well. Sometimes, opening the Camera app just shows an Icon of a camera and nothing else on a black screen.
The front-facing "selfie" camera works just fine, but can only be accessed by telling Google "Take a Selfie", otherwise the "Warning: Camera Failed" prevents you from getting there.
Here's what I've tried:
Rebooting Phone
Clearing Camera Cache
Clearing Camera Data
Reset Camera Settings
Clearing Gallery Cache
Clearing Cache Partition
Trying Alternative Camera App
Starting Phone in Safe Mode
Deleting Recently Installed Apps
I DID NOT factory reset, and I DO NOT want to unless absolutely necessary. Knowing my luck, I'll factory reset and it still will not work and then I'll be out of all my data.
I also DO NOT have a phone repair store in this little small town I live in.
The latest update on phone is G996USQU4BUKF
Hopefully someone will be able to provide assistance,
thanks!
SamsungAdam
I understand how frustrating this is. Here is a link with troubleshooting steps that may help. https://www.lifewire.com/fix-camera-failed-error-samsung-galaxy-4176450 and https://www.samsung.com/us/support/troubleshooting/TSG01001329/
If the troubleshooting is not helpful, the phone will need to be evaluated by a certified technician. For service in the U.S., you can take the phone to a local U.S. walk-in service location https://www.ubreakifix.com/samsung  or to ship the phone in for service, please reach out to us via one of the following options:
1. Facebook Messenger: http://m.me/samsungsupport
2. Twitter: https://twitter.com/messages/compose?recipient_id=18768513-
3. Private Message: https://bit.ly/3hzZfw8
If the PM link is not working for you, you can click on my name and send me a private message directly from my profile.
For service outside of the U.S., please use this link: https://www.samsung.com/us/common/visitlocationsite.html
thoughts
Comet
Probably a hardware failure. Back up your data with smart switch for Mac os or windows. Then reset the phone
user751201tmO21
Honored Contributor
So, how long have you had this phone?
You've had these issues since "day one" ... or was there some "event" where you suddenly see the issue?
Faddy
9
Partwo
Same. Samsung replaced all the camera's to no avail, then replaced my S21 Ultra with a new phone that has network comnectivity issues. So now I've got a fancy camera but can't even make a  phonecall from my own home. It's so frustrating
Who_Is_John_Galt
Same issue here as of this AM
Wickster
Same issue. Factory reset didn't work. Cleared cache partition and repaired apps. Still same issue.
Billyf
Ben, had same issue with my S-20 Ultra, less than a month, noticed this happened after update. Called it in, did all what they told me to do. Still did not work, so they sent me a refurbished phone. I rejected it and told them this is a new phone. Had to go to Samsung directly. They sent me a phone, worked great. Until this week. Got message Camera failed. Had phone for a while now, so I do agree this is either a hardware issue or programming issue. Only fix I know of is replacement.
userh8NdKGjYjJ
Same issue since one UI update late November, I have performed all the same and a factory update and still not working!!
SamsungAdam
