Ultra S21 Camera Problem (White Spots and Shadow)
(Topic created: a month ago)
Tan CS
Galaxy S21
I had just purchased Ultra S21 a week ago and i was very disappointed with the camera. In the night time when i tried to take pictures there are white spots and round circle shadows moving around as i tried to take pictures. It looks like light reflected inside the lens and its very disturbing to the picture quality. I actually had the same problem with my samsung S8+ but i didn't bother with it. But it is very disappointing to had the same problem with this premium model that i paid for it. Check out the photos below for the mentioned problems. Please advice how to solve this problem
20210921_211044.jpg20210921_211106.jpg20210921_211138.jpg20210921_211203.jpg20210921_211214.jpg20210921_211255.jpg20210921_211317.jpg
Je655
Red Giant
Galaxy S21
It looks like a lens flare from the light directly above you. I would check out this article.
https://photographylife.com/what-is-ghosting-and-flare
Galaxy S21
Are you using some type of lens protector?
Tan CS
Galaxy S21
no i did not have any lens protector on it
floydvoid
Galaxy
Galaxy S21
have you adjusted the camera settings? try turning down the saturation. my s21 ultra came stock with it maxed out which left a bright red circle around the sun in every picture i took with it in the background. looks a little like what's going on in your picture of the moon.
go to: camera> more> pro> manual and adjust settings to your preference. hope this helps
SamsungQue
Galaxy S21
I can understand how this can be frustrating. I would recommend trying the troubleshooting steps here.
